Engine Dies
Old Oct 23, 2011 | 11:13 AM
dools103's Avatar
Engine Dies
I have a 1995 F150 with 5.0 motor, put a new cap and rotor on it and now all of a sudden I will drive a block or two and it just dies out as if the key was turned off, turn the key off starts back up littleways down the road dies out again, wires are on corectly, idles smooth, thought maybe the igniition switch jiggle it it cut off then tried it without iggling it and it still died and that was sitting still so don't think it is that, did not touch anything under the hood except move the air intakes out of the way and the cap and rotor, Help!!!!!!
Old Oct 23, 2011 | 11:14 AM
Need4racin's Avatar
pull codes, check fuel pressure. clean idle air control
