Question for poweraid owners or throttle body spacers
Old Jul 19, 2001 | 12:44 AM
StevensBlack4x4's Avatar
when you put the poweraid on did you fill an difference in performance and mpg
Old Jul 19, 2001 | 06:58 AM
Joe T's Avatar
No NONE
Old Jul 19, 2001 | 07:02 AM
crazyaboutF150's Avatar
Hi StevensBlack4x4,
Well, when I added my Poweraid spacer, I had installed the K&N Generation II intake system, a Pro-M 80mm MAF, and a 75mm BBK TB.
What I experienced and learned is this, the 4.6 doesn't breath as well as the '99 and up 5.4's with the P.I. heads. With all of the additional volume of air that I was pullling into my 4.6, it was leaning out and bogging down the engine. When the Poweraid spacer was installed, after the other mods, it significantly improved my performance and power. This spacer increased the velocity of increased air volume throught the design as advertised.
I also tried the spacer without the 75mm TB and putting the stock TB on with the other mods and it ran like crap! I tend to agree with others on the board that have tried this spacer with a stock setup and it doesn't improve power or performance. On the other hand, make modifications like I have and its the only way or the optimun way that my 4.6 will produce more hp.
Something that I have left out of the equation here, my custom Superchip helped significantly in enhancing the performance of my 4.6 with all of my modifications. The stock ECU just could not compensate enough for the mods I had made for optimum power and performance.
Old Jul 19, 2001 | 10:34 AM
doorslammer69's Avatar
Smile
Crazy:
Did you get an improvement by installing the poweraid with the 75mm t-body before installing the custom chip?
Old Jul 19, 2001 | 12:55 PM
dvldog458's Avatar
I put my spacer in with a 56mm edelbrock throttle body.It seemed to the run smoother and rev quicker.
Old Jul 19, 2001 | 03:45 PM
Smile
Yes I did get an improvement from installing the Poweraid spacer prior to the Superchip. However, I was already running a Jet chip that 5150phD is running with now.
