4.2L
Old Jul 28, 1999 | 01:35 AM
rsmckinley's Avatar
Post 4.2L
need performance parts besides chip,exhaust, and air fitler. If not know, parts needed to swap in a 4.6L in a 97 f-150 with 4.2L and man. trans.
Old Jul 28, 1999 | 06:20 AM
Darin's Avatar
Lightbulb
rsmckinley, It would probably be cheaper and you would end up with the same HP if not more than a 4.6 V8 -- Send your 4.2 V6 to a good machine shop to be rebuilt and have them balance and blueprint it as well as port and polish the heads, while waiting for the engine work send your intake to Extrude Hone.
Old Jul 28, 1999 | 03:18 PM
rsmckinley's Avatar
Post
Darin,
can not have the truck down for that long. but i did think of that. thanks for the input.
Old Jul 28, 1999 | 10:27 PM
Darin's Avatar
Post
Then find a junkyard V6 .... you really think a 4.2 to 4.6 swap will take less time?
Old Jul 28, 1999 | 10:53 PM
rsmckinley's Avatar
Post
yes i do. a weekend or less should be more than needed.if i have all the parts to do it.
[This message has been edited by rsmckinley (edited 07-28-1999).]
Old Jul 29, 1999 | 01:03 PM
NascarBill's Avatar
Post
Actually, I have done some research into this swap and the only difference in the 4.2L and the 4.6L wiring is the Injector harness and the Processor. The main wiring is the same. But, A weekend will be a feat to achieve.
Old Jul 29, 1999 | 02:08 PM
rsmckinley's Avatar
Thumbs up
buy the way guys i have 3 day weekends not 2 days. and nascarbill can you share any more info. on the subject. and tina i do not have a way to post pictures. thank you for the help anybody.
[This message has been edited by rsmckinley (edited 07-29-1999).]
Old Jul 29, 1999 | 08:08 PM
NascarBill's Avatar
Post
I believe you will have to change the transmissions also. Its gonna be a lot of work, but if you have found a wrecked vehicle with all of the accessories, you will be in much better shape.
Old Jul 29, 1999 | 10:26 PM
garthr's Avatar
Lightbulb
I believe the 4.2 and the 4.6 use the same transmission,code 44U.Only the 5.4 uses code 44E.This was from the info I used to order my truck from Kelly Blue Book.
Old Jul 30, 1999 | 12:24 AM
Tina's Avatar
Lightbulb
If you do manage to do this swap, PLEASE take some pictures and try to get them posted here.
97F150 XLT SC 4x4 Flairside 4.6 V8 5sp Dk Toreador Red, 3.55LS
ARE tonneau cover, p255/70rx16 tires (came w/235), Superchip
Pioneer CD w/4 Polk Speakers & Clarion APA5240amp, skid plates
bed liner, side window deflectors, reese hitch, K&N air filter
40s-2chamber Flowmaster, Bosch +4 spark plugs, rustproofing
Better Built Stainless nerf bars
Old Jul 30, 1999 | 12:51 AM
Tenderpaw's Avatar
Red face
rsmckinley, no offense intended, but to pull off a V6 to V8 swap in one weekend would be quite a feat! I could see physically getting the V6 out and the V8 engine mounted in the truck over a weekend, but sorting out the electronic engine controls and wiring harnesses to get it running sounds pretty challenging.
'93 Regular Cab XLT Shortbed, 5.0, K&N, Borla, 160,000 miles; Future SuperCrew owner.
Old Jul 30, 1999 | 05:57 AM
NascarBill's Avatar
Post
They use the same transmission type (4R70W), but the bellhousings have different patterns.
The 5.4L uses the E4OD.
Old Jul 30, 1999 | 11:18 AM
Tenderpaw's Avatar
Post
While the V6 and V8 may use the same model transmission, I would advise against using the V6 trans. In the past, there have been internal differences in transmissions of the same type based on the engine they are to go with. For example, and AOD trans for a 3.8 V6 had fewer clutches and other weeker parts than its 5.0 V8 counterpart, even though the V6 trans could physically mount on the V8. Of course since the bellhousings are different on the 4.2 and 4.6 its a mute point.
