Battery light came on? HELP?
Old Oct 1, 2011 | 12:15 AM
Danielf91's Avatar
What can cause this? Its a 2000 supercrew 5.4 4x4
Old Oct 1, 2011 | 12:33 AM
Alternator. Go to the parts store and get the battery and alternator tested.
Old Oct 1, 2011 | 09:03 AM
Do what glc said and also check your connections......
Old Oct 1, 2011 | 10:26 AM
jbrew's Avatar
Check your alternator fuse. The inline fuse.
Old Oct 1, 2011 | 10:40 AM
BLUE20004X4's Avatar
For sure, along with the checking of alternator and battery.
Old Oct 1, 2011 | 01:13 PM
Danielf91's Avatar
checked alternator and battery they seem fine the guy at advance auto said its a drian some where possibly? what could be draining the system.
Old Oct 1, 2011 | 01:23 PM
jbrew's Avatar
A bad connection. Check that loop down by the starter, - sometimes they hold water. You have to go thru your cable connections/grounds.
Keep in mind that MOST of the time and with light illumination, it is an alternator fault. Doesn't have to be of course, in my experience it has been.
So after going thru it and if the problem still exists, -look closer at the Alt.
Old Oct 1, 2011 | 06:34 PM
JCR 56's Avatar
I'm thinking alternator.
