Stumbling 02
Old Sep 24, 2011 | 07:57 AM
Erocvt's Avatar
Unhappy Stumbling 02
02 4.6 stumbles upon acceleration, when i have the pedal held steady in one position RPMs drop to about 1300/1400 give it gas and it hesitates and sputters like its not getting fuel.Ive replaced the plugs, dpfe sensor, MAF,TPS, fuel regulator, EGR valve is only a year and a half old. if i get on it or left off the gas the stumble goes away , Ive gotten a P0003 code( which im told I shouldnt) and a EGR valve circuit low code.
Old Sep 24, 2011 | 09:01 AM
jbrew's Avatar
Try the fuel filter next
Old Sep 24, 2011 | 09:11 AM
Erocvt's Avatar
replaced the fuel filter last fall
Old Sep 24, 2011 | 09:43 AM
jbrew's Avatar
Which DTC's scanned other than the PO 003 ?
MIL present ?
Has the MIL blinked at any time?
Old Sep 24, 2011 | 01:14 PM
Coils? Did you use Motorcraft plugs?
Old Sep 24, 2011 | 03:09 PM
Erocvt's Avatar
yes motorcraft plugs coils were tested when i did plugs a month ago. this afternoon SES started flashing( misfire?) but no misfire codes when i hooked it up to the Modis
Old Sep 24, 2011 | 05:40 PM
How were the coils "tested"? The only way to do that is at the dealer with quite expensive test equipment.
Spend the 100 bucks and buy a 10 pack of DG508's from Global or Uneek on Ebay - that way you will even have a couple spares.
Old Sep 25, 2011 | 03:44 PM
Erocvt's Avatar
ok ordering them today let you know how it turns out
Old Oct 12, 2011 | 06:53 PM
Erocvt's Avatar
so replaced the coils that were bad, and no more stumbling, thanks guys,
