Lack of Power
Old Sep 11, 2011 | 12:07 PM
chuck gibson's Avatar
Lack of Power
Hello Folks,
I have a 2000 F-150 with a 4.6 V8 with approx. 35000 miles on a rebuilt engine. The thing seems to have no pep to it. It hesitates during acceleration and I don't even want to try towing my RV with it.
The computer has thrown no codes;
A vacuum check shows it running about 18.5 pounds of vacuum. When revving the engine, the needle drops to 0 and then shoots up to about 22# before returning to 18.5;
I tested the vacuum lines by using an UNLIT propane torch all along the vacuum lines with the engine running with no change in the idle;
Where do I go from here?
Thanks,
Chuck
Old Sep 11, 2011 | 12:16 PM
Veteran: Army
#1 it's a 4.6, obviously it feels like it lacks power
#2 obviously without a power adder it won't make boost
#3 when is the last time you did any maintenance / what was done / what parts were used???
Old Sep 11, 2011 | 01:25 PM
Go to a muffler shop and get the cats and the rest of the exhaust system tested for blockage.
Old Sep 11, 2011 | 03:13 PM
#1 It has had a lot more power in the past;
#2 What is a "power adder"?
#3 Replaced plugs, used autolite double platnums. Replaced two COP's, swapped around the rest of them with no apparent change in idle.
Thanks!
Old Sep 11, 2011 | 03:15 PM
Great suggestion! Do you know how they test these systems?
Old Sep 11, 2011 | 03:58 PM
Veteran: Army
a power adder that would add boost is a supercharger or turbocharger
you're running plugs that are known and proven to be useless in your truck might want to change them to some motorcrafts
I agree with having the cats tested if the plug change doesn't help the "power" department
Old Sep 11, 2011 | 04:51 PM
I think they pull the front O2's and hook up a pressure gauge. I also think they can do it with an infrared temperature sensor.
