5.4 problems
Old Sep 7, 2011 | 06:09 PM
bowhunterAH's Avatar
5.4 problems
truck will start today run great. tomorrow it may not start next day it will. hour later it will. new battery fuel pump and stuff. when it wont start its not getting spark but turns over great . what could this be. it wont shoot a code
Old Sep 7, 2011 | 07:46 PM
Toyz's Avatar
What year is the truck...
Old Sep 8, 2011 | 06:20 PM
its a 2002 fx4 offroad
Old Sep 8, 2011 | 07:13 PM
Toyz's Avatar
When it is not starting but turning over, is the theft light on the dash bezel flashing? How did you determine it is not getting spark when there is a no start issue
Old Sep 8, 2011 | 09:54 PM
sprayed starting fluid in it when we cranked it
Old Sep 9, 2011 | 06:24 PM
enriched's Avatar
Seems that you need to check the fuel pressure...make sure that the new fuel pump is doing its job.
was the fuel filter changed as well?? was it part of "stuff"?
make sure all you fuel lines are connected well....it maybe getting a little leak (not enough to leak out), but enough to create a air lock or suck air in.
when this doesn't start....try, (or have you tried), cycling the key On and Off a few times (3-6 times)...then try starting again.
Old Sep 9, 2011 | 07:12 PM
Alexcngford's Avatar
Take your truck to a mechanic. Starting fluid on a fuel injected engine isn't a good idea. you need to get a definite answer on if you are getting fuel and spark.
Old Sep 9, 2011 | 10:08 PM
jbrew's Avatar
Exactly lol. Yea, don't do that , you'll smoke the TPS ribbon. Here's usually the problem with your symptoms.
1. The battery. As unlikely as that sounds, they can do that when you drop below 11.8 volts.
2. Fuel regulator on the rail. When the regulator acts up, the rail can over-pressurize,- therefore shuts the injectors down.
3. Pump, that's an easy test, - KOEO, you'll hear it charge the lines. If not, pop the hood and touch the relay. If it's warm/hot its bad.
If you don't hear the pump and the relay checks out, slide under and hit the tank w/hammer, in the middle.
