Antifreeze leak problem
Old Aug 31, 2011 | 12:08 AM
brandon56's Avatar
I got back to the house today and heard a hissing noise from my engine. I popped the hood and sure enough my antifreeze was spraying out of I don't know what. I have put two links to the pictures I have, and I have drawn arrows to the area where as far as I can tell it is leaking from. Can y'all tell what it is or has anyone else had this problem? Could my intake manifold be cracked? (I am a rookie) The truck has 211,000 miles on it, its a 2000 5.4, the intake manifold is the original still. Any help is much appreciated.
Thanks, BB
Old Aug 31, 2011 | 12:10 AM
brandon56's Avatar
For some reason I dont see the links to my pictures on my post. Well they're in my album on my profile named "antifreeze leak problem."
Old Aug 31, 2011 | 12:55 AM
jethat's Avatar
I've seen that before think that fittings busted and that means you need a new intake..
Maybe some one whos had that problem will chime in but I've seen it before. Not repairable.. New intake. Rock auto sells them for $193
Old Aug 31, 2011 | 06:59 PM
Toyz's Avatar
Yesir... that is the coolant crossover. Part of the intake manifold and was common to crack/leak on the underside of the connection from the composite to the aluminum crossover. Intake manifold will need replaced. Make sure and get the revised manifold (where the problem was fixed)
Post number 2000. beers for me
Old Aug 31, 2011 | 07:12 PM
brandon56's Avatar
Well looks like I need a new intake manifold then. Never convenient the first week back to classes. Any specific suggestions toyz or jethat as far as where I get it and which one? I see it need to be the revised addition.
Thank y'all, this forum always saves my a--.
Old Aug 31, 2011 | 08:08 PM
jethat's Avatar
Rock auto only carries one-that means that's most likely the only option because rock auto carries almost every thing..
