04 f150 p2106 p2135
P0121 - Throttle/Pedal Position Sensor A Circuit Range/Performance For Vehicles With Electronic Throttle Control (ETC)
P2106 - Throttle Actuator Control (TAC) System - Forced Limited Power
P2135 - Throttle/Pedal Position Sensor/Switch A/B Voltage Correlation
I would venture a guess that these all are related to one issue. Possible wiring or sensor not connected right.
Steve, I will need to remove your other post, as only one per subject is allowed.
Are you asking what the code mean? If so, there is a list in th Articles and How TO Section:
https://www.f150online.com/forums/ar...-dtc-list.html
Here is the P0121:
P0121 Throttle/Pedal Position Sensor A Circuit Range/Performance
Here is the P0121:
