200 f250 superduty help
Old May 25, 2011 | 09:10 PM
aswviper1's Avatar
Just changed the fuel pump, filter, the fuel relay and still wont start fuel is getting up to the engine now but not going into the injectors can anyone help AND IT WILL FIRE WITH STARTER FLUID
aswviper1's Avatar
And its a v10 2wd
Old May 26, 2011 | 05:09 PM
lukes mobile's Avatar
is the security light flashing when you try to start it? the pats system shuts the injector driver off so it wont start could be as simple as needing a new key
Old May 26, 2011 | 08:57 PM
aswviper1's Avatar
so there is a gurgling noise when the fuel pump turns on up by the injectors but i cant find a leak anywhere and how would a new key help since there is no chip inside the key
Old May 26, 2011 | 10:31 PM
Toyz's Avatar
Correct me if I am wrong but the 00 F250 had the PATS system. Which would mean it is a programed key. Same question as before... is the theft light blinking while trying to start it????
Old May 26, 2011 | 10:46 PM
Gotts2BMe's Avatar
no pats on the superduty's till 08
Old May 28, 2011 | 08:38 PM
aswviper1's Avatar
when the fuel pump is engaged it sounds like its sucking in air so its not building up preasure
Old May 28, 2011 | 10:07 PM
Toyz's Avatar
Weird, could have swore my dads 02 had it.
