Problem Fixed for now :)
Old Jan 9, 2011 | 02:55 PM
marks2006f150's Avatar
Well everyone I posted here a couple of days ago to get some advice on what could be causing my 2006 f150 ( 4x4 with a 5.4L and 70000 miles on it ) to be jerking and sometimes cutting off. I got a code of 2104 and 2112. Well I took some advice from you guys and a good friend that I needed to clean my throttle body. I was really susprised at how much carbon buildup there was inside the throttle body; so I decided to remove the entire throttle body and do a good cleaning. After cleaning it I replaced the o-ring under the throttle body and put everything back together. I did however manage to break the small clip on the inside of the TPS plug so now I have to replace it (easy fix) I started my truck up and MAN O MAN it runs like a new truck! I am amazed at how well the truck accerates and shifts its a world of difference. THANKS EVERYONE FOR THE HELP!!!!!! Next step is going to be replacing the spark plugs and fuel filter This will be done at 100K Wish me luck on the spark plugs
Old Jan 9, 2011 | 04:56 PM
jbrew's Avatar
Why did you start a new thread ? - Should have continued the one your referring to, - so we can read it to.
Doesn't make sense. Well, if I helped yuh, - your welcome I guess
Old Jan 10, 2011 | 12:31 PM
Jbrew sorry about starting a new post. All help was appreciated and thank you for your advice. I dont use forum sites to often but I just wanted to let everyone know that I solved the problem and wasnt thinkin about replyin to the original thread; thanks again for the advice from EVERYONE!!!
Old Jan 11, 2011 | 02:32 AM
jbrew's Avatar
That's okay, thanks for posting anyway. Usually, people won't say anything. They post all over the net, -even PM you, looking for information and once someone offers it to them, they take it and disappear without saying a thing.
I sort of took those frustrations out on you, I apologize for that, - your not that way.
