What gauges do you have in your truck?
Yes. Besides using it for diagnostics and stuff I can use it to help me save fuel. I'm a visual person, the point is it keep the vac up as high as possible. I have a heavy foot.. Lol
A voltmeter monitors the entire system - an ammeter only monitors the circuit that passes thru it (typically the battery, less the starter circuit). That's why Ford stopped using an ammeter in '86 & has used a voltmeter ever since.
yes, so it monitors the charging system(starter, battery, alternator).
GLC, I think I am going to do an oil pressure gauge for my second gauge. My water temp gauge seems ok. thanks. Now to find out how to hook it up. I'm going with an electric.
nevermind, i see the point to tap in, its above the oil filter. I'll get the t adapter and the electric sending unit.
Thank you everyone for your help. I really appreciate it.
Last edited by lightningx54; Dec 22, 2010 at 07:35 PM. Reason: problem self-solved
The factory "coolant" temperature gauge actually gets its input from the cylinder head temp sensor. It comes up in a linear fashion from "C" to the middle as it warms up, and then stays right in the middle without moving at all till it's overheating, at which point it pegs out immediately at "H" and trips the idiot light. About 15 seconds later, the alternate cylinder deactivation cuts in and the CEL comes on. I'd like to have a gauge that would be linear all the way up and actually measures the coolant temp.
This may help clarify it to you:
An ammeter shows Drain & Charge. An alternator can never be a drain, and a starter can never put out a charge. So obviously, half the ammeter's face would be wasted on either of them. And if you ever study physics, you'll learn that a single display can't measure current (Amperes) at 2 or more points simultaneously; only 1.
Note that the switching indicated on those diagrams occurs in the PCM - not in the CHT, which has a linear output.
That's not entirely true either. The stock gauge reaches it's "normal", resting position by 160*. It will not move from this position to indicate an overheat until the temperature increased above 235*. I don't know about you but that is not how I expect a gauge to work...especially one that supposedly indicates in a linear fashion.
How do you think that could be accomplished, anyway? The sender (which those diagrams show to be proportional) is connected directly to the gauge, and the gauge is just 3 coils. It's not built to have a flat response to a linear signal increase. It would take some kind of processor to hold the gauge while the sender rises, and that's just not present - certainly not in gauges up to ~'04 when they all became stepper motors, but why would Ford waste the effort to add it? The closest thing to what you're describing is the Anti-Slosh module (and its later version called Gauge Check) that retards the fuel level from rapid changes (but DOES allow the change over a few minutes), and it has a discrete digital output for the indicator light. And in '87, the oil pressure gauge became a fully-fake when the sender was deleted and a switch & resistor were substituted.
But there's nothing on the temperature gauge to alter its display from mirroring the sender.
That's an easy one to answer...the exact same reason the oil pressure gauge is not real. It works the exact same way. It doesn't fluctuate with a fluctuation is real oil pressure. Why?? Because Ford got smart after installing "real" oil pressure gauges in cars a few years back. After getting droves of people coming in complaining about the needle moving around and thinking there was a problem, Ford installed the idiot light with a needle. Water temp is the exact same thing. Under normal perfect conditions, your water temp can fluctuate plus or minus 10* in some circumstances. Ford doesn't want this reflecting in the needle and people bringing their cars in to get the "problem" fixed.
The temperature conditions I listed in my last post are not my interpretation of how I think the gauge works, nor was it regurgitated info I just picked up on here...I have a real water temp gauge and I'm telling you that's how my needle reacts. Best answer I have for ya.
The question you quoted only applies to a HEC - the kind with stepper motors. Your '02 gauges work this way:
So the temperature gauge ISN'T a fake, and never has been. People understand that engines run hotter in hot weather & colder in cold weather, so the reasoning behind the oil gauge doesn't apply.
If your temperature gauge has a flat spot, it's defective.
Originally Posted by Ford
Engine Coolant Temperature Indication System
The engine coolant temperature indication system is a magnetic gauge system. It consists of a magnetic engine coolant temperature gauge mounted in the instrument cluster and an engine coolant temperature sender unit.
Engine Coolant Temperature Gauge
The engine coolant temperature gauge is a magnetic gauge movement consisting of three primary coils, one of which is wound at a 90-degree angle to the other two. The coils form a magnetic field which varies in direction according to the variable resistance of the engine coolant temperature sender unit. A primary magnet, to which a shaft and pointer are attached, rotates to align to this primary field, resulting in pointer position. The bobbin/coil assembly is pressed into a metal housing which has two holes for dial mounting. There is no adjustment, calibration, or maintenance required for this gauge.
Engine Coolant Temperature Indicator Sender Unit
When the engine coolant temperature is low, the resistance of the engine coolant temperature sender unit is high, thus restricting the flow of current through the gauge, and moving the pointer only a short distance. As the coolant temperature increases, the resistance of the engine coolant temperature sender unit decreases, causing a proportionately increased flow of current through the engine coolant temperature sender unit and a corresponding movement of the pointer.
My new (used 2002) GMC Savana Has real gauges. My water temp in my E350 or my F150 does not fluctuate like it does in the Savana. Oil pressure is real to. Ford should have taken the time to educate there (dumb) customers and not just thought were all stupid. I like the real gauges in that van. Dont really like the van itself its already broken down on me. Water pump only had it 10 days. I never have had a down day in my E350 in 8 years.
