Voltage Drop
Old Dec 5, 2010 | 05:47 PM
wells420's Avatar
Voltage Drop
Ok so I have a 92 F150 5.0, when I have my headlights on, defrost on and I come to a stop sign my lights dim, fan slows down and the voltage gauge shows a drop. I have replaced alternators, batteries, add a 4 gauge ground from the engine to the body and body to frame. My next thought is to install a high amp alternator but Im not sure what to do. Any advise would be great.
Old Dec 5, 2010 | 06:18 PM
Toyz's Avatar
Is the idle dropping when this happens? Or almost stalling.
Old Dec 5, 2010 | 06:21 PM
Labnerd's Avatar
If you've already replaced the alternator, sounds like you're not buying a large enough battery. I buy the best 65 series battery Wal Mart has and it carrys all of my vehicles at idle. Any issues with the battery and it's a Wal Mart problem. I also haven't paid for a battery since the 1990's as WalMart keeps replacing them- too cheap!
wells420's Avatar
Yes the rpms drop a little too. The other issue i have with this truck is that when you start it, it has what i would consider a rough idle until it "catches" itself then idles normal
Old Dec 5, 2010 | 06:24 PM
wells420's Avatar
I get the best group 65 from carquest which has 880CCA. It's a good battery manufacture, East Penn, they also manufacture Deka.
Old Dec 7, 2010 | 07:51 PM
Steve83's Avatar
Originally Posted by wells420
...a 4 gauge ground from the engine to the body and body to frame.
It should go from the alternator case to the (-) clamp on the battery - nothing else will help this symptom. Read these captions:
If you ultimately decide to upgrade the alternator (which shouldn't be necessary), just get a stock 130A 3G that fits your engine & wiring harness. Don't waste the time & money of an aftermarket alt that requires ANY modification of the truck.
