What year of engines will swap into my 91???
Hey every, i own a 91 F150 4x4 5speed 302 and have terrible problems with it. i recently bought it for dirt cheap but i believe it needs an engine swap or rebuild. it has 135k miles on it and the oil pressure drops off the gauge after about 10mins of driving. I believe there is very little compression in it and it struggles to accelerate in 4th and 5th gear.
I purchased an oil pressure today from Autozone to manually test the pressure but im about 95% sure this engine is done for. It started smoking really bad under the hood when i was less than a mile from home.
I was wondering what year of engines would swap directly into the truck. I believe an 87-91 were the years but will a 92 or newer engine swap directly in? also, would this affect my transfer case since its an on-the-fly shifter (i believe thats what its called) and i believe that later year models have a push button shifter??? Correct me if im wrong or add anyone pointless information you want, ill read it all
i don't have much experience with trucks/cars but ive rebuilt a million dirtbikes/ATV engines so you can throw anything at me
Nothing you've posted so far indicates the engine is beyond repair, or even in bad shape. My engine has over 400Kmi, and still runs strong. The '88 5.0L I put into a friend's truck had more miles on it than yours when we pulled it out of the junkyard, and it runs perfectly.
The oil gauge is a fake, and the switch that controls it is known to fail that way. Read this caption & the links in it:
Why exactly do you "believe" compression is low? Read this:
Smoke can come from any of the fluids in the truck, or anything that splashes up from the road, so again: it means nothing until you ID the source. If the engine is too dirty to spot leaks, wash it. I prefer Gunk Engine Brite (not the foamy version) - read the instructions on the can. It may take several cans & several washings, but doing it at a car wash will speed up the process. Just don't blast the distributor or vacuum lines, or be prepared to dry it out before you try to start the engine.
There's a VERY wide range of engines that will fit, depending on how you do it. The 302ci/5.0L short block didn't change significantly over its production run (ending around 2001), but I certainly wouldn't put in an older engine. Any EFI short block or long block would be OK & fairly easy, but the '98-up Explorer/Mountaineer 5.0L complete engine would be a real upgrade, if you also transfer the wiring & computer with it. For that matter, virtually ANY engine will fit in that engine bay; even a V10 or diesel. Check this out:
