Battery load?
Battery load?
Usually when I start up and drive my Gryphon tuner has always read 14.0 - 14.2 battery voltage. Since yesterday on startup it starts at about 12.6 volts and increases to and holds at 13.8 volts. I have added new DDM HID's and had to change a fuse on my tail when I crosses the LED tail wiring. I have checked the install of the HID's and everything looks good.
Good Luck.
1. Perform the SScully Battery Test: https://www.f150online.com/forums/4380878-post18.html
2. Get rid or that crap DDM garbage. (fyi - See sig for the proper way to do HID's.)
3. Good luck. My bet is on the battery starting to migrate south fer the winter, lol.
MGD
________________
MGD
________________
BTW, I also liked this post here, -
there have been scattered reports of people on this message board getting several "bad" alternators in a row from the auto parts store. if you've got corrosion like pictured above, you can install all the alternators you want and still not have the charging system work properly.
Yea, just something I didn't think of.
