Pulleys...?
Old Nov 22, 2010 | 05:42 PM
BlueOval_Man's Avatar
Pulleys...?
Are they worth it? What size belt will I need if I go with BBK?
Old Nov 22, 2010 | 06:03 PM
jbrew's Avatar
You need pulley's. How do you plan to keep your battery charged, among other things. Of course their worth it.
BBK ? You mean underdrives ?
Old Nov 22, 2010 | 06:14 PM
Way to be a smart ***.
Yes BBK UDP's.
Old Nov 22, 2010 | 06:24 PM
jbrew's Avatar
Way to be a the ladder... Lighten up, it's just the internet.
Old Nov 22, 2010 | 06:38 PM
Galaxy's Avatar
https://www.f150online.com/forums/v8...e-pulleys.html
Plenty of reading if you do a little searching.
Old Nov 23, 2010 | 03:52 PM
Veteran: Army
way to make the most of your education Sir...
anyway, they will use a stock sized belt, if you read the directions / advertising you will see that a stock belt is what you'll use
I prefer the MAC pulleys over the BBK's but I might be a lil' biased
Old Nov 23, 2010 | 04:09 PM
JimmysotherFORD's Avatar
use one with an SFI approved balancer , not the piggy-back style they can/have destroyed oil pumps. you could go with a steeda kit for a mustang (99-04 gt) it'll bolt up as along as you make sure it's for the water pump you have. (1/2 through 01 ford started using and water pump with a shorter shaft.)
