DPFE voltages
Old Sep 10, 2010 | 09:24 AM
JMC's Avatar
JMC
25 Year Member
DPFE voltages
I would appreciate any help with my issue. I have the 401 code but I need voltage readings to help diagnose the problem. The connector has 3 wires. I have 4.7 volts on 2 of the wires Key on engine off. Could anybody check their wires and report back on the voltage readings. Of particular concern is the Brown with Light Green striped wire. That is the return signal from the sensor. Mine has 4.7 volts and I do not think it should.
Old Sep 10, 2010 | 09:31 AM
MGDfan's Avatar
Hey.
I don't have one to check, but Google brings up some troubleshooting hits - here's one, while you wait for Jbrew to reply :
http://www.slideshare.net/Fordlovers/ford-dpfe
MGD
Old Sep 10, 2010 | 12:14 PM
jbrew's Avatar
This is a good sensor ~
http://picasaweb.google.com/jbrew393...07882591006386
Old Sep 10, 2010 | 12:19 PM
jbrew's Avatar
You still need a check "Key Off " ? I can do that.
Old Sep 10, 2010 | 12:22 PM
JMC's Avatar
JMC
25 Year Member
I appreciate all the answers but I really need the voltage values of that Brown with Light Green wire. Unplugged, I forgot to mention that it was unplugged when tested, with Key on Engine off it reads 4.7v. This wire should not have any voltage with the connector unplugged or less than ½ a volt.
EDIT The reason for the request is that I suspect that this wire is either shorted to the 5v reference or the PCM is FUBAR'd.
Old Sep 10, 2010 | 12:26 PM
JMC's Avatar
JMC
25 Year Member
I posted before you posted this. Yes please. If you don't mind.
Old Sep 10, 2010 | 12:27 PM
jbrew's Avatar
Alright, I'll check it , right now.
Old Sep 10, 2010 | 12:31 PM
jbrew's Avatar
Hang on, I can't find my keys. :o
Old Sep 10, 2010 | 12:40 PM
jbrew's Avatar
Yea it's hot, I got , Key On ~
5.06 Brown/Grn stripe.
5.06 Brown/Wht stripe.
Middle wire, I got 0.03
I have the Aluminum DPFE, so it's going to be a little dif on voltage.
Old Sep 10, 2010 | 12:50 PM
jbrew's Avatar
Key off I get barely anything on the Brown/Grn = 0.02
"0" on the other two.
Old Sep 10, 2010 | 01:11 PM
jbrew's Avatar
Here's Scorpio's data buddy -(uk) ~
http://www.fordscorpio.co.uk/egrsensors.htm
Old Sep 10, 2010 | 01:17 PM
jbrew's Avatar
Originally Posted by MGDfan
Hey.
MGD
- I haven't seen that one , that's a keeper
Old Sep 10, 2010 | 02:23 PM
JMC's Avatar
JMC
25 Year Member
Thanks jbrew. That is exactly what I needed. My ref voltage was 4.7 last time I checked but both those wires were the same. I can now proceed with my diagnosis.
Old Sep 10, 2010 | 02:30 PM
jbrew's Avatar
No problem
Old Sep 10, 2010 | 08:46 PM
Klitch's Avatar
Dang Jbrews too fast, I was gonna say I remember vaguely that it was on the list of sensors with the 5v Vref wire.
