Noise outta the intake (is it serious???)
Old Sep 2, 2010 | 10:18 PM
Kr619's Avatar
Hey guys been having this problem for a while but all of a sudden the noise was getting louder and louder to the point that if i'm at a stop light I can hear it. It sound like a backfire something like a blupp blupp blupp I have no trouble code and the cars running like its old crappy self but I'm just concern it may be trouble lurking down the corner and if I prevent it might as well take care of it now. Oh yeah and it only happens while idling. Thanks
car info:
03 expy, 4.6l, 120, xxx miles, k&n sys
Old Sep 2, 2010 | 10:43 PM
jbrew's Avatar
You sure it's coming from the intake? The only noise that I can think of is one that the PCV valve makes when partially plugged. If you have a scanner, scan it anyway, -you may have something pending. Without a DTC it's hard to say. If she's running bad @ idle, I would check the EGR valve.
Make sure your engine light is working. Turn your key to run, it should illuminate regardless.
Are you up to date on your fuel filter ? The fuel system would be the next to check out. Check pressures. Also, makes sure the MAF is clean.
Old Sep 3, 2010 | 12:00 AM
nonwoven29's Avatar
See if this sounds like your issue??https://www.f150online.com/forums/su...ing-noise.html
Old Sep 3, 2010 | 01:37 AM
jbrew's Avatar
Yea, that's called the IAC horn and it's a 4six thing. The 5four is different, -horns in the back and it's round. That one slipped my mind , but that's correct , IF the engine is running correctly. You need to integrate that black box back into the line.
Old Sep 3, 2010 | 02:01 AM
Kr619's Avatar
I did most of the maintenance less than 500 miles ago I don't move the truck as much anymore so I'm sure it ain't any of that or I hope it ain't. The only code it throws is a p1000 but thats probably cause I had a vacuum leak and I haven't ran the truck more than 5 miles after that.
It ain't a howling noise its more like when you submerge something under water like a bottle and the air bubbles are escaping. I'ma see if I can find a way to record the sound. If its eating up antifreeze will that be a problem. . .THANKS GUYS
Old Sep 3, 2010 | 11:46 AM
JimmysotherFORD's Avatar
p1000 means you reflashed the computer reset and there is no info in the emissions computer, it will go away after a few weeks of driving.
Old Sep 3, 2010 | 11:55 AM
MGDfan's Avatar
Just throwin' this out there for comments....
This:
Originally Posted by Kr619
... It ain't a howling noise its more like when you submerge something under water like a bottle and the air bubbles are escaping.
Plus This:
... If its eating up antifreeze will that be a problem. . .THANKS GUYS
Equals trouble, imho ...
I do not believe in coincidences. Have you checked yer oil for water, and/or checked yer overflow tank fer oil?
Good luck.
MGD
Old Sep 3, 2010 | 06:44 PM
Kr619's Avatar
Nope no water in the oil or oil in the antifreeze . . . I asked a mechanic friend and he says it maybe a head gasket (due to the fact that I told him about the antifreeze which he says may be going out the tailpipe) so i took out the oil last night and since there was no water into it i threw it back in this morning. But theres no white or blue smoke so thats why I hope its not the gasket . . . THANKS
