Bad MAF wire harness
Old Aug 14, 2010 | 02:08 PM
airman19's Avatar
I have 97 F150 4.6l V8 with 152000. I have troubleshot the check engine and maf down to a bad wire harness. The only issue is now finding a new one. I am having no luck with local autowreckers and according to Ford they do not produce the part anymore. My question is has anyone had to replace the wire harness between the maf and engine wiring harness and if so where did you get it. Thank you.
Old Aug 14, 2010 | 02:19 PM
jbrew's Avatar
Have you checked it ? It's easy enough to check and replace wires if you need to. You can purchase that harness tho, -somewhere. I can't recall where at the moment. Look in the electrical forum, search that forum for Ford Pigtails and connectors. There's a PDF file.
