help help need more hp!!
I didn't have a Denso to check at the time, but I'm running those (Iridiums). The only difference I noticed with Iridiums so far is that my City mileage has improved. Highway mileage is the same tho. 16 City 16 Highway on cruise @ 78-79 mph.
plugs
Thanks for the head's up... I do agree that it's always a safe bet to use OEM parts as much as possible.
I've never once, had an issue going from Motorcraft to Autolite plugs. I have had issues with Bosch, NGK and Champion plugs. I actually had a '74 LTD with a 351W that would foul out every brand of plug I threw at it until I tried AC Delco's. Go figure???
Iridium are great plugs... Are they still running around $10 a piece?
James
James
James
James
You can get Iridium's for between 7 - 8 bucks a piece @ Rock auto.
Double Platinum's - 103's and 104's
plug resistance
I performed a thread search but couldn't locate a thread on plug resistance. I did find numerous positive and negative threads on Autolite plugs depending on the truck year model. All good stuff to know when it's time to replace the plug's on my STX.
Thanks...
Thanks...
sorry couldnt help myself
