Engine won't start
Old Jul 12, 2010 | 12:38 AM
fritz4077's Avatar
No it does not crank..u turn the key and nothing
Old Jul 12, 2010 | 01:57 AM
dannycruz837's Avatar
Just throwing an idea but check your fuse box. look in your manual and check the fuses that could have anything to do you starting system or those you think might be a problem. Haha i forgot to replace a fuse that had something to do with my fuel line and my engine wouldnt start. Just disconnect negative battery terminal if you decide to check them.
Old Jul 12, 2010 | 02:20 AM
JMC's Avatar
JMC
25 Year Member
Did you short the terminals or just turn the key?
Old Jul 12, 2010 | 11:38 AM
fritz4077's Avatar
just turned the key..
Old Jul 12, 2010 | 09:59 PM
JMC's Avatar
JMC
25 Year Member
Why didn't you short the terminals? I am trying to help eliminate a PATS issue. If the PATS is shutting down the PCM the engine will crank but not start. If shorting the terminals does not engage the starter then there is a starter or wiring problem.
Old Jul 13, 2010 | 03:57 PM
fritz4077's Avatar
ok i figured out one problem the starter was bad just got a new one..who knew they only last 2 months....so my next problem is its cranks but doesnt start could it be possible the fuel injectors are clogged..the trucks been sitting for about 3 weeks
Old Jul 13, 2010 | 04:06 PM
I highly doubt that 3 weeks is enough to plug all the injectors to a point where it wouldn't even cough.
Okay, you either have no spark or no fuel. Have you reset the fuel inertia switch? Have you checked for fuel pressure? Have you checked for spark? What does the THEFT light do when you turn the key on?
Old Jul 13, 2010 | 04:18 PM
fritz4077's Avatar
i got spark....got 45 psi at the rail...reset the switch....and the theft light blinks when i turn the key
