L motor and W motor
Old Jun 14, 2010 | 06:27 PM
thesnowman269's Avatar
L motor and W motor
how impossible would it be to swap a 99 5.4 with the L engine code into a 98 with the 4.6 W engine code? What all is needed? i have the chance to buy the motor for 150 bucks but dont want to spend the money on it if It cant be done. any input is appreciated
Old Jun 14, 2010 | 06:48 PM
f150fella08's Avatar
yes it can be done. thats the very common 4.6-5.4 swap!
https://www.f150online.com/forums/ar...wap-notes.html
Old Jun 14, 2010 | 07:35 PM
jbrew's Avatar
No problem, -you won't even need a re-tune, but it's a very good idea to. Use your 4.6 ignition components (coil packs). Leave the high tech CoilOverPlug (COP) system from the 5four on the shelf.
f150fella08 has posted user JMC's excellent "Note's Bible" link above. Your all set now
Old Jun 14, 2010 | 11:19 PM
so you can run a 5.4 off the 4.6 coil packs? hmm i always thought you would have to run everything over to COP's
Old Jun 14, 2010 | 11:56 PM
jbrew's Avatar
You could, but - coil drivers are different with the 4six PCM. Firing orders the same. So - well, it's a hassle programming in COP systems when you don't have to, -basically. There may be more to it than what I'm thinkingat the moment. From what I recall, -most , if not all, run the 4six CoilPacks for the 5four on this swap.
Old Jun 15, 2010 | 12:02 AM
makes sense.
Old Jun 15, 2010 | 02:49 AM
Sweet! I know what im doing tomorrow! i know the motor needs a rebuild. the guy who has it said it was getting moisture inside the cylinders, he replaced the head gasket but didnt help, any ideas whats wrong? i Plan on rebuilding the engine as it is anyways, just looking for a place to start. thanks!
Old Jun 15, 2010 | 09:24 AM
umm...cracked head, block, warped head??
Old Jun 16, 2010 | 01:43 AM
wouldnt a cracked block cause engine failure not just moisture in the cylinder? i could see it being a warped head that would make sense i geuss
