Driving with bad COP?
Old Jun 14, 2010 | 11:14 AM
bm4183's Avatar
2003 4.6 F150
Will it hurt to drive my truck with a bad COP? I have ordered a new set and will replace them all when the arrive.
Thanks.
Old Jun 14, 2010 | 12:42 PM
It can be rough on the cats - if it's a solid miss you may want to unplug the injector for that cylinder.
Old Jun 14, 2010 | 01:33 PM
Galaxy's Avatar
I wouldn't do it. It's not going to want to "go".
Old Jun 14, 2010 | 05:13 PM
38Chevy454's Avatar
To expand a bit, you will dumping unburned fuel into the exhaust which makes the converter run really hot and you could burn it up. Unplugging the injector just makes it a dead cylinder. You can drive with the dead cylinder, it just will be a complete miss and run bad, but not doing any real damage.
Old Jun 16, 2010 | 06:56 AM
bm4183's Avatar
I ended up driving it for a few hundred miles, but I'm not driving anymore until I get the parts to fix it.
How would I know if I burned up the cat?
Old Jun 16, 2010 | 07:33 AM
Veteran: Army
I'd be more worried about how much you ended up washing down the cylinder wall
Old Jun 16, 2010 | 09:07 AM
jbrew's Avatar
Originally Posted by bm4183
2003 4.6 F150
Thanks.
Depends, how bad is it ? Low misfire or is it dead ? If it's a low grade misfire, -reboot every 40 miles or so, she'll fire more after a fresh boot and misfire between 45 and 55 mph or right after she shifts into OD under normal acceleration.
If it's dead, unplug the injector.
But, - I wouldn't drive it, - if I didn't have to. It's definitely not good for it, -any way you look at it.
