engine oil
Old Jun 11, 2010 | 09:01 PM
RobPad's Avatar
engine oil
what's a good engine oil and filter to use in the 5.4?
Old Jun 11, 2010 | 09:13 PM
jethat's Avatar
This topic has been covered HUNDREDS of times. Please use the search feature..
Old Jun 11, 2010 | 09:14 PM
risupercrewman's Avatar
MotorCraft 5W-20 Syn/blend & a FL820-S filter will serve you very well!
Old Jun 11, 2010 | 11:01 PM
jetech00001's Avatar
pick up the oil and filter at wallmart motorcraft oil $ 11.40 5 qt jug and motorcraft filter $ 3.47 FL820-S AND 5W-20
Old Jun 12, 2010 | 12:28 AM
Toyz's Avatar
+ 1 more quart for $2.77 (6qt fill)
Old Jun 12, 2010 | 02:18 AM
7 quarts if you have a 5.4.
Old Jun 12, 2010 | 11:38 PM
Pilot's Avatar
I run Motorcraft 5-20 in all my vehicles. One has 154,000 miles and no oil burn. This oil is semi synthetic and cheap at Walmart for $2.77 qt. This is a great oil for the price and hard to beat. I do all oil changes at 4,000 miles and keep computer records of each of 4 vehicles.
Old Jun 14, 2010 | 09:58 PM
Roadie's Avatar
GLC, You scared me! I went out and looked at my 2002 owner's manual and it confirms that my 5.4 takes 6 qts with filter change. That is what I've been putting in it.
Did they change the fill to 7 qts in the 3 valve engine?
My 05 Dodge Magnum "Hemi" 5.7L does take 7 qts. If I bought a new truck (which I don't plan to do. I love my 02 Ford) I would have to consider a Dodge because of that wonderful "Hemi" engine.
Old Jun 14, 2010 | 10:51 PM
Labnerd's Avatar
Wait until you see how many qts the new 5.0 holds. I bet a lot of the owners won't be changing every 3000 miles. The 3V holds one more qt than the 2v 5.4.
Old Jun 14, 2010 | 11:07 PM
jethat's Avatar
3v's do take 7 quarts. Ford has new engines in the new trucks right now. the new 5.0 and 6.2 engines may be the cutting edge right now.
Old Jun 14, 2010 | 11:58 PM
f150fella08's Avatar
the new 5.0 takes 8quarts i believe
