Changing plugs
Old May 28, 2010 | 09:50 PM
4INTHEDRIVEWAY's Avatar
Changing plugs
Hi everyone, I am planning on changing plugs in a 2001 4.6 L as it has 250,000 km. on it and has never been done. It is my old work truck that i bought after i got a new one and I have not changed them before on the newer style with what i think they call the COP. So basically can someone give me a little instruction on how to do it, or is this going to be a nightmare. I don't really want to take it into the dealer because of the mileage on it. Thanks for any response.
Old May 28, 2010 | 10:13 PM
Welcome to the site. This thread has some good info.
https://www.f150online.com/forums/v8...s-2-valve.html
Old May 28, 2010 | 11:18 PM
I have read on this forum a problem with the spark plugs breaking. Is that a common problem ?
Old May 28, 2010 | 11:21 PM
The breakage problem is for 2004-early 2008 with the 5.4 3v, so no, you don't have that worry. You just need to torque to 28 ft/lbs with no antisieze, to help resist the plug blow out.
Old May 29, 2010 | 02:01 PM
Thank you, that helps a lot, only problem is I have a 2006 with that motor also. LOL
Old May 29, 2010 | 02:05 PM
Well,, you are in for some fun then! Actually, it is not as bad as it once was. Do the research, follow the TSB and have the Lisle tool ready just in case. Or, do like I did and take it to a dealer that knows what they are doing and is fair about it. There is a lot to read on here, when you are ready.
Old May 29, 2010 | 02:35 PM
My 2006 only has 13,000 km on it so It should be good for a while.
