valve cover bolts needed
Old May 27, 2010 | 01:55 PM
Jeb_713's Avatar
i am looking for a set of valve cover bolts for a 99-00 5.4L 2 valve windsor engine. i need all 27 bolts
Old May 27, 2010 | 02:17 PM
jbrew's Avatar
Jeb,- your going to have to call the dealership for that one most likely. That's the easiest route. Unless you run across someone that has a set,= unlikely.
You might check ARP. They make Torque to yield head bolts for these engines, - it's possible for them to carry cam cover bolts, - I'm not sure.
BTW-Valve cover and Cam cover are sort of the same (on the outside only). Cam cover is what you would use when searching, that is the part you need bolts for. Valve cover references older engines, non OHC.
