Hhhmmmm- Replaced O2 sensors today
PART NUMBERS anyone???? I called AA and all they have is Bosch for $89 EACH!!! I've looked online but am a little confused as different part number says the fit the same vehicle model years. Anyone have Motorcraft part numbers for a 2003 FX4 Lariat 5.4L???--DirtySCREW
Which is better between the Bosch and MC?
When I click on the DY835 Motorcraft O2 sensor to see what it fits(on Rock Auto); it says:
FORD F-150 (1999 - 2004)
FORD F-150 FX2 (2007 - 2008)
FORD F-150 FX4 (2005 - 2008)
FORD F-150 HARLEY-DAVIDSON EDITION (2001 - 2008)
FORD F-150 HERITAGE 2004
FORD F-150 KING RANCH (2005 - 2008)
FORD F-150 LARIAT (2005 - 2008
Ok, I have an F150 FX4 Lariat. According to the chart, it fits 99-04 F150s but the FX4 and Lariat start at 05....and mines an 03. I guess I'm asking if the FX4 package or Lariat has something different or will these still work and the chart is wrong?
Thanx---DirtySCREW
Thanx---DirtySCREW
Thanx---DirtySCREW
Thanx---DirtySCREW
On Rock Auto you look up year and model. That way you get what's recommended for your truck. Iduno, they make it easy unless somethings changed.
You have an F150 and they have your part for your year. None of the others apply. I don't get it, what's so hard lol.
Motorcraft and Bosch are both good. Bosch is OEM for our trucks, but you can run either. Motorcraft may have an slight advantage over Bosch according to one tuner that I know off, -other than that, - either or.
Jbrew---Yes, I have a 2003 F150......and Yes its a FX4....and Yes it has the Lariat package. I was just trying to make sure that the FX4 lariat didn't need a different part as its $120+ dollars.
glc---Thank you
---------------------------DirtySCREW
glc---Thank you
same issue
I seem to have a similar problem. Won't hold speed uphill and needs to downshift. Low idle and a little ruff, not much. Only get about 15mpg this time of year and use to get 16-17mpg consistant.
Where are these sensors located? I have a 2001 XLT Supercrew 4x4 4.6 w/154k.
Recently replaced plugs, cops, filters, egr tube, pcv vlv., right exh. manifold
Anything else to look for?
Thanx - Dean
Thanx - Dean
Thanx - Dean
Thanx - Dean
They are on the exhaust pipes by the cats.
Thanx - I found a post that had step by step instructions to change the sensors. Seems really close to what I have.
Plugs are OEM, COPs were bought from online site recommended here (ebay). Local garage changed pcv when doing plugs, so not sure what brand.
Thanx
PS, now I have a noise from belts/pulley, probably idler pulley. This thing is just starting to want all kinds of attention. New SensaTrac shocks, like a new ride. Just a little more money ( :<) ) and I'll be good for a couple more years. Yea, sure!
I bought it new in Nov 2000 and I WILL have a hard time parting with it some day!!!
Thanx
clearly auto has denso o2 sensors for $34 they also have bosch and others cheep
http://www.clearlyauto.com/catalog/1...word/O2-Sensor
that link is for the 4.6 97 - 03 just go to the home screen and put in what ya got
Paul, you might have leaky fuel injectors.............
https://www.f150online.com/forums/v8...ram-07m08.html
