Car Engine For Truck Engine
Old Mar 17, 2010 | 09:36 PM
Clance54's Avatar
Will a 4.6 or 5.4 out of a car work in place of a trucks engine as long as they are the same engine? Thanks for he help ahead of time!
Old Mar 17, 2010 | 09:47 PM
Other than the Ford GT and the Mustang... not quite sure.
Old Mar 17, 2010 | 10:17 PM
chrmar's Avatar
The 5.4 only goes in Australian cars and very expensive Mustangs... so we won't worry about that. As for the 4.6, you can use one out of a car. You need to change the valve covers, intake manifold and oil pan. If your truck already has a 6-rib belt setup, then you're good to go otherwise you'll need to change over some pulleys.
Cars only ever had the Romeo version of the 4.6, I believe, so if you have a Windsor in your truck there's some more work involved.
