Dry Starting
Old Mar 17, 2010 | 04:44 PM
JMC's Avatar
JMC
25 Year Member
Originally Posted by d_dyer
After running to town i got back home and crawled under my truck and i can hear the oil draining back into the pan so i don't think it is the viscosity of my oil causing my problem and the filter and oil was changed 1k ago with mobil oil and a mc filter so i also don't think the drain back valve is leaking so what else could it be? Is there a device in the oil pump that holds the oil in the engine?
Thanks for your help.
Check the oil pressure release spring in the oil pump. They go soft after a while.
Old Mar 17, 2010 | 06:47 PM
d_dyer's Avatar
How would i go about doing that?
Thanks!
Old Mar 17, 2010 | 08:28 PM
Labnerd's Avatar
Just because you have a Motorcraft filter doesn't mean it's not leaking. The anti drain back valve is not intend for prolonged periods of holding the oil while the truck sits. I'd change the filter only and see if that fixes the issue. I would suggest using a 5w-30 high mileage oil next time. The 5w means it will get pressure quicker. Going to a heavier oil at temp buys you nothing for your issue.
Old Mar 18, 2010 | 01:09 AM
masseyman's Avatar
You could try a different brand filter. If you have a John Deere machinery dealer near you, ask for a John Deere brand oil filter for a number 800 John Deere windrower(1970s vintage). I can post the filter number if you wish. The 800 engine is a Chrysler slant 6. The filter it takes interchanges with a Motorcraft FL-1A. I tried running Motorcraft oil filters on it, but I had the start up noise you're having. Just a suggestion.
Old Mar 18, 2010 | 03:45 AM
d_dyer's Avatar
It happens even if it set for a couple hours, and the motor only has 68k on it is that considered high mileage? Thanks for the input!
Old Mar 18, 2010 | 03:49 AM
d_dyer's Avatar
The closest JD dealer to me is about 60 miles and being out of work it is hard for me to go to the store so i kinda dont have the money for gas going there. do you know if autozone sells them? could you post the filter number please?
Thanks!
Old Mar 18, 2010 | 03:55 AM
mcolford's Avatar
Autozone does not carry John Deere. You may try looking online, and just having it shipped to your house. Shipping on an oil filter would not be very much.
-Matt
Old Mar 18, 2010 | 05:01 PM
masseyman's Avatar
The John Deere filter number is TY9425. It says on the box made FOR Deere and company, I don't know who makes these filters. It also says on the box "all new car warranties remain in effect when John Deere filters are used" if that's worth any peace of mind. I checked online, the current price at my local John Deere dealer is $3.72 each, this may vary slightly from dealer to dealer.
Old Mar 18, 2010 | 05:30 PM
If you want to try a different brand of filter that may be available locally and not expensive, try a Purolator Pure One, Wix, or NAPA Gold.
Old Mar 18, 2010 | 08:52 PM
masseyman's Avatar
The oil filter study that was done years ago claimed that the Purolator Pure One was the same as the Motorcraft FL-1A(if memory serves me well). I assume they are still the same, so you may want to skip the Pure One or try it last.
Old Mar 19, 2010 | 07:23 AM
I'm not sure it's a full Pure One - the Pure One has a silicone anti-drainback valve where the standard Purolator has something else.
