4Wheel Drive WONT Engauge?
Old Feb 21, 2010 | 02:27 PM
marks2006f150's Avatar
I have a 2006 F150 with the 5.4L engine. I am from SC and dont really use my four wheel drive that often. I do switch it into 4hi and 4low at least twice a month to keep componets lubercated. Last week we got about 6 inches of snow and I had to use my 4HI just a little bit on the dirt roads. Everything worked just fine and had no problems at all. Today (2-21-10) I was out scouting for turkeys and had to engauge my 4 wheel drive in some mud. Needless to say nothing happend. I stopped completly turned the switch to 4Hi and nothing happened. No lights, No sounds,and No signs of 4 wheel drive engauging. I checked all my fuses and nothing is blown. I also disconnected my battery and let sit for about 30min before reconnecting it and still nothing works.CAN ANYONE HELP!!!! Thanks Mark
Old Feb 21, 2010 | 03:39 PM
jbrew's Avatar
No response from user
Old Feb 27, 2010 | 06:06 PM
BigTrouble's Avatar
You should have a motor on the transfercase with all of that snow it could have went bad. I have a 1999 f150 supercab 4x4 off road with the manual transfercase shifter i haven't ever had any trouble out of mine locking in
Old Feb 27, 2010 | 07:39 PM
jethat's Avatar
I dont really know anything about the 04+ trucks but the first thing I'd check is the vacuum system.
Old Feb 28, 2010 | 11:38 AM
You might get a better response in the other powertrain section - the transfer case doesn't have anything to do with V-8 engines.
Old Feb 28, 2010 | 08:19 PM
JT33's Avatar
i would check your front end for a broken c-clip cuz i had the same problem and it was just a 38 cent c-clip that broke in side
