differantial
Old Jan 30, 2010 | 11:25 AM
MadePlayer's Avatar
differantial
i have a 1991 f-150, how can i tell if it has a positrac rear?
Old Jan 30, 2010 | 11:59 AM
Neal's Avatar
Cool
HI!... Well there's 3 common ways to tell if you have a Limited Slip differential.
1 - The tag on the differential cover will have "LS" stamped into it.
2 - You can actually removed the differential cover and physically see if you have Limited Slip.
3 - Jack the rear of your truck up (on jack stands) Have someone hold one of your rear tires. Then you try to spin the opposite tire. If your fighting against your buddy, then you have Limited Slip. If it spins freely with no resistance against the other rear tire, then you have a open differential or your clutch packs in your Limited Slip are worn out.
Old Jan 30, 2010 | 12:16 PM
jethat's Avatar
On the door tag if the axle code has a letter in it its factory LS number it open. Example H9 is 3.55 LS, 19 is 3.55 open.
Old Jan 30, 2010 | 08:37 PM
avfrog's Avatar
^ x2
Old Feb 6, 2010 | 12:11 PM
MadePlayer's Avatar
thanks a lot....my '91 has H9, my '99 has 19
Old Feb 6, 2010 | 05:36 PM
Old Feb 7, 2010 | 10:35 PM
Camarothatcould's Avatar
I have H9!!!!! WOOHOO
Old Feb 7, 2010 | 11:40 PM
MTM Ford's Avatar
Me too. Wish it was 3.73's though.
Another way to check is go do a brake stand or burnout.
Old Feb 7, 2010 | 11:50 PM
truck cant do brake torques... but somehow in the rain or snow I dont go anywhere unless im in 4x4...
