98 Expy 4.6 (2) codes, water on top of #3
Old Jan 20, 2010 | 05:06 PM
wiseguy's Avatar
Exclamation 98 Expy 4.6 (2) codes, water on top of #3
Haven't contributed here but am willing to help when I can. Need any marine electronic advice. I'm your guy but heres my plea for help!
98 Expy 4.6W on the way home (1 hour into 4 hr drive) started running poorly. CEL began blinking the steady then blinking. Pulled into AZ and got scanner. Codes were P0303, P0171 & P0174.
Did my research and found the crack in pvc fitting behind intake man. Pulled #3 plug boot and found the boot to be wet which appeared to be rusty water. Checked oil (changed a week ago) No water found in oil. However Res tank appears a bit low. Pulled plug appeared norm maybe a lil black from no fire I've read where hose leaks and maybe even head gaskets can cause this. Would a blown gasket cause water to collect around the plug boot?
Give me your thoughts
Old Jan 20, 2010 | 05:18 PM
jethat's Avatar
Check the hoses above #3 heater hose leaks down into #3 & 4.
Old Jan 20, 2010 | 05:48 PM
wiseguy's Avatar
I did take a look at those hose with the funky fittings on the end. They seem intact, but from what I've seen there's been a lot issues with those
Old Jan 20, 2010 | 08:56 PM
jbrew's Avatar
Coolant comes from the opposite end of those hoses with funcky fittings lol.
Yea, it doesn't happen all the time, - only when conditions are met. It's a high pressure burst. You have a leak.
Old Jan 20, 2010 | 10:59 PM
wiseguy's Avatar
that and brew, thanks for your suggestions. I will check them if not replace
Old Jan 21, 2010 | 12:08 AM
jbrew's Avatar
Yea, checkout what jethat and I suggested. There's not much else it could be.
Old Jan 21, 2010 | 12:19 AM
FoMoCo Fan's Avatar
blow out the hole and keep going, the water is prob rusty cause it's been there since you last washed the engine. Di-electric the coil pack on re-install.
CEL??? you mean MIL maybe?
don't think coolant can get in there any other way than driping in from above so head gasket is out of question.
Old Jan 21, 2010 | 12:38 AM
jbrew's Avatar
Originally Posted by FoMoCo Fan
don't think coolant can get in there any other way than driping in from above .
Yes it can, that was half explained.
Old Jan 21, 2010 | 03:50 PM
autotech88jtaw's Avatar
Yup i had the same exact problem with my truck, the heater core hose only cost me 17$ from advanced auto so not too bad. replacing it is not too bad either unless the dam fitting at the heater core doesnt want to come off, which happened to me, the plastic that you push in to get it off was jamed full of dirt, so what i did was use a dremel to cut the plastic locks off, which then it came off great and it snapped on and no problems since, just make sure you have to hose all the way down the tube on the intake also.
Old Jan 21, 2010 | 06:54 PM
wiseguy's Avatar
First off thanks to all you have taken the time to help out. I have yet to find the leaking hose but I plan on checking it out more intensely Fri morn while off from work. I did however notice a strange "trickling sound" from under the dash today on the way home. Damm lil Gremlins.
