What do I do for a tune up?
Old Jan 3, 2010 | 03:04 AM
vlad90's Avatar
i know that sounds dumb.
i have a 2002 ford f150. what I should replace and/or change?
is it hard to change the spark plugs?
whats the name of some good spark plugs to put on my truck?
Old Jan 3, 2010 | 03:22 AM
chester8420's Avatar
No, not dumb. But the days of "tune ups" are mostly over. These newer trucks "tune up" themselves all the time. But there are a few things that need to be replaced at specific mileages as preventative maintenance... Like the serpentine belt, trans fluid, spark plugs etc. So, the next appropriate question would be; How many miles are on your truck? What maintenance have you done already? Is it running good?
Old Jan 3, 2010 | 04:12 AM
One Shot Luni's Avatar
New plugs, air filter if dirty, oil change. Make sure all fluids are full; brake, coolant, power steering etc. Greese joints if havn't done within recommended milage, change plug wires as well. I would also put some injector cleaner in the fuel. Clean out your throttle body and mass flow meter. Stuff like that.
Old Jan 3, 2010 | 04:36 AM
alex7191's Avatar
The plugs on the back of the motor are difficult to change. Use Motorcraft plugs. and yeah, i'd clean the MAF and throttle body. I don't think fuel filter has been mentioned yet.
Old Jan 3, 2010 | 09:00 AM
vlad90's Avatar
Thanks guy! For not laughing at my question lol and chester8420 I just got my truck last summer she's parking in my garage, I'm from colorado and I can't drive it in the snow she's only 2WD...booo I know it sucks but I love the truck and I wanna make it faster. The truck has 90,000 miles is runs great, but I don't know about any maintenance.
Old Jan 3, 2010 | 10:42 AM
Pitbull260's Avatar
if i were you and i jus got the truck and you dont know prior maitanace id change everythig thats mentioin then use that as a base start off for you so you know. i jus got mi truck about 2 weeks ago and plane on doing all that.
Old Jan 3, 2010 | 11:09 AM
jethat's Avatar
pre cat 02's are about due with them miles to.
Old Jan 3, 2010 | 10:41 PM
I personally wouldn't touch these components unless you have a problem. Your computer will let you know if any of these need servicing.(check engine light will come on) You can do more harm than good by pouring additives into your fuel and playing with the air metering and emmissions systems.
I agree with the other suggestions, plugs etc. I also like to change my trans fluid and filter every 100,000 or so too. (it'll shift smoother) Check your drive shaft u-joints, brakes, inspect and pack (or replace) the front wheel bearings (every time you do brake work), clean and grease caliper slide rails (every time you do brake work), change serpentine belt, inspect the PCV hose where it meets the back of the intake manifold, and look the entire truck over really good for anything unusual.
Old Jan 4, 2010 | 12:15 AM
vlad90's Avatar
thanks everyone for all your help!!! It looks like I have a lot of work to do this summer!! Lol
Old Jan 4, 2010 | 12:26 AM
jethat's Avatar
CEL does not illuminate for clogged fuel filters nor does it illuminate when 02's are working poorly only when they no longer work at all. Fuel filters are OEM recommended 40k change and 02's are recommended 100k. Both these items WILL make the engine run poorly if neglected.
I agree Most injectors cleaners are snake oil. Cleaning the throttle body WILL improve performance....
Old Jan 4, 2010 | 01:04 AM
Yes it will. It will show lean due to lower fuel pressure. Unless you are dumping dirt in your tank they don't stop up anyway.
The computer monitors O2 switchrate and if the requested fuel trims (based on O2 info) doesn't jive (fairly close) with the MAF's air volume approximation, then it will also light the CEL.
If you have a performance problem..... I wouldn't risk breaking it or stripping out a bolt hole if its running good already!
I don't skip important maintenance that could potentially damage my truck. But I skip the stuff that is monitored by the computer, and wouldn't hurt or disable the truck if it failed. This is my humble opinion, however; so do what you will.
Old Jan 4, 2010 | 10:41 AM
Norm's Avatar
I drive my 2wd every winter in the snow. Not a problem. You just need to learn how to drive in snow. 140K on mine now. I do not go off road with it but I commute 55 miles a day.
Old Jan 4, 2010 | 11:59 AM
aroncull's Avatar
Thanks for the thread guys. This is exactly what i needed.
Old Jan 5, 2010 | 12:52 AM
vlad90's Avatar
well i know how to drive in the snow lol but i just dont wanna drive it cuz i have 24 rims with low profile tires 305/35r24 and trust me it sucks in the snow i have a truck for the snow.
Old Jan 5, 2010 | 06:58 AM
Veteran: Army
use motorcraft spark plugs, oil filters, bosch o2 sensors
