Possible bad EGR Valve
Old Dec 29, 2009 | 11:12 AM
airman19's Avatar
Question Possible bad EGR Valve
I have a 97 f150 4.6 xlt. Just recently I started having an issue when i accelerate from a stop i pretty much have to gun it to keep it from dying out on me. If i hesitate and don't push the gas past the first about 1/4 in the truck hesitates and lurches horribly. Then just yesterday it started to lurch extremly bad at highway cruising speeds and on light loads like accelerating up a small hill. I replaced the plugs, gas filter, cleaned the air flow sensor nothing is working. I think from what I have read it is probably the EGR stuck open but would appreciate any input. Thank you.
Old Dec 29, 2009 | 11:58 AM
AZTriton's Avatar
Sounds more like your IAC or TPS sensor. Is your CEL (check engine light) on? Need to get the DTS codes read. Stores like Autozone or Checker/O'Reilly's will do it for free.
Old Dec 29, 2009 | 05:38 PM
airman19's Avatar
Alright I had to buy the OBD reader because due to some legality Orielys and Autozone say they can no longer shoot codes. I pulled a P0102 and P0113 which was low reading on mas/air circuit and high reading on mas/air ciruit. After reading the chilton it the symptoms of a bad TPS sound about right but I wanna see if this sounds more like the mass air sensor
Old Dec 29, 2009 | 05:43 PM
jethat's Avatar
Clean the MAF sensor. Thats were I'd start. Easy cheap.. Right next to the air filter you take it apart. You have to buy a safety torx to get it apart and pick up some MAF cleaner..
Old Dec 30, 2009 | 12:54 AM
AZTriton's Avatar
Either way, clean your MAF sensor but you're probably going to have to replace the TPS. It's about $60 or $65 bucks for a Motorcraft. I wouldn't buy a non-Motorcraft as many have had bad luck from them.
