Misfire.....misfire....misfire....help please!
Old Dec 5, 2009 | 08:07 AM
bamacpl's Avatar
I know this has been beat to death! & I've read most every thread..........
I have pretty much the same problem as most everyone with a 5.4 150---misfire under a load usually around 50-55 mph, very rough idle etc....
--This has been going on for me for the past 3-4 yrs. It is usually the back 2 COP's against the firewall.
Once it happens I swap them to the front 2 so they are easilly accessable if they are bad. Once I swap them it will run great for a while usually 6-12 months, then the same routine over again.
The general advice seems to be replace all COP's & plugs with oem motocraft. I have replaced all my plugs, but why all the COP's if they really aren't bad----or are they? They work fine once I swap them (basically re-seat them on a different cylinder)
----I guess my question is: How can I cure this problem for good without blowing alot of money on unnecessary components?
Yesterday it happened again & the CEL blinked for about 10miles till I stopped & never stayed on. I went hunting for a couple hours, then when I went to drive back home it ran like a champ....no misfire, no CEL!
Old Dec 5, 2009 | 10:22 AM
chester8420's Avatar
Quit wetting your motor. Dirty motors run better.
Old Dec 5, 2009 | 10:25 AM
jethat's Avatar
You cant afford $65.00 for a new set of coils? if you had read about the tuning of the 5.4 on this board you would know you can get them on e-bay.. Replace them and be done with it. Make sure you have Motorcraft plugs..Make sure you water proof them with Dielectric grease to.. And these..
http://cgi.ebay.com/ebaymotors/NEW-I...item58847a0c54
Old Dec 5, 2009 | 10:50 AM
no-mams's Avatar
could be bad injector, need an injector flush, reprogram pcm to latest calibration.
Old Dec 5, 2009 | 04:21 PM
bt1911's Avatar
It's a good question and I don't think it's a problem of affordability. It's a problem of crappy design since he asked what he can do to keep from changing out the COPs every year which is stupid to have to do on any vehicle. I particularly don't like removing all the skin off my knuckles and bleeding all over my engine every time I change out the back two, either.
Old Dec 5, 2009 | 06:56 PM
jethat's Avatar
They wear out in about a 100k. Replace ALL of them and they dont wear out for another 100k. Replace them 1 at a time and yes they will fail every few months until you did them all. Makes it seem worse then it needs to be.
Old Dec 5, 2009 | 07:25 PM
built54's Avatar
Replace them all and the problem should be fixed. I dont see it being an injector issue at all.
Old Dec 5, 2009 | 11:52 PM
No they don't. I have over 300,000 miles on 7 of my F150's factory set (1 broke). My father has 250,000+ on his V10's factory set. My uncle has 200,000+ on his factory set. My mother has almost 200,000 on her 1997 4.6 with coil packs.
As far as I know, they never wear out. They're solid state. But they hate being wet.
$50 says that the original poster washes his engine.
Old Dec 6, 2009 | 04:31 PM
jbrew's Avatar
Yea, I call BS right there lol.
You wouldn't have to ask quote #2 if quote #1 was correct. It's a cheap fix and allot of users on this site take advantage of it. Yes, it's been beaten to death, but the good in that is simple fact, = It's a proven fix
Old Dec 7, 2009 | 08:13 AM
bamacpl's Avatar
I did read most every thread on this subject & have been monitoring them for a few years now....I just wanted to see if someone would reply with a new & improved fix.
$65 for new coil overs is not the issue, as I stated above was just fishing for a new & improved fix.
Thanks for all the helpful posts I will just change all of them again along with plugs.
---about the bleeding knuckles----that is TRUE as hell as it seems to usually be the back 2 against the firewall!!!! :-(
Old Dec 9, 2009 | 10:56 PM
so..... Do you ever wet your engine?
Old Dec 10, 2009 | 08:28 AM
bamacpl's Avatar
no, never have wet it! I pulled #6 yesterday which was the one that was misfiring.....was all kind of moisture in it & was even a little of corrosion on the plug itself!
I don't know where the moisture is coming from? I am gonna get all new COP's & plugs & put some kinda sealer on the top of the rubber boot where it meets the top of the plug well! I don't know what else to do?
Old Dec 10, 2009 | 09:03 PM
AZTriton's Avatar
Dielectric grease. Coat the entire inside of the boot; just make sure to clean the tip of the spring before putting it in the well. You want good contact between the spring and top of the plug. I pull the spring out past the end of the boot & spray with electronic cleaner to make sure there's no dielectric grease on the tip of the spring. Also coat any seams on the COP/boot with dielectric grease. Last time I removed the COP's, the seal was very good it took some pulling to get them out. sounded like a wine cork being pulled!
And though most here know what can happen when these engines get wet, the Ford manual (at least with my '03) states:
" Engines are more efficient when they are clean because grease and dirt buildup keep the engine warmer than normal. When washing:
-Take care when using a power washer to clean the engine. The high-pressure fluid could penetrate the sealed parts and cause damage.
-Do not spray a hot engine with cold water to avoid cracking the engine block or other engine components.
-Spray Motorcraft Engine Shampoo and Degreaser (AC-20) on all parts that require cleaning and pressure rinse.
-Cover the highlighted areas to prevent water damage when cleaning the engine." (highlights the intake filter, battery & fuse box)
I wonder if they have the same recommendation in '04 & later manuals...
Old Dec 10, 2009 | 09:07 PM
bamacpl's Avatar
AZTriton & others who replied w/helpful info:
Thanks for being so helpful! I appreciate your time to reply back with some helpful info!
Thanks!!!!
Old Dec 11, 2009 | 07:34 PM
Well find out what is wetting it!!!
Dry it off and plug it back in, and it will probably work.
