cant get the fuel filter off
Old Nov 16, 2009 | 09:48 AM
wayne r's Avatar
Hi, I posted a thread entitled engine wont start and it was suggested I replace the fuel filter, my problem is I cant get the filter to release I bought the tool to remove the filter but cant seem to get it to release the coupling from the fuel line, why they dont move the filter location down one foot I dont know, mine sits on the frame rail right where the cross member intersects which makes it difficult toget to, the tool I used was from harbor freight not sure if a higher quality tool is necessary wondering if anyone else has had this problem any suggestions would be appreciated, have to try one more time before bringing it to the mechanic thanks wayne r
Old Nov 16, 2009 | 09:54 AM
push the line in towards the filter, then try and slide the tool and line off the filter together
Old Nov 16, 2009 | 10:09 AM
If you are using the aluminum tool, it can sometimes be too thick to go in far enough. A better tool is th plastic ones that come in a set. Same ones used in airconditioning service. However, sometimes, the clip is rusted or dirty and will not release. I had changed mine successfully, several times and ran into one that would not release. I took it to a lube shop and they ended up yanking the clip out and replacing it. they indicated that it is not uncommon.
Old Nov 16, 2009 | 10:46 AM
jethat's Avatar
I hold the tool tight and push the filter towards it. Works better then trying to push the tool.
Old Nov 16, 2009 | 11:38 AM
jbrew's Avatar
A catalyst will help on the stubborn filters. Or a penetrant, that reminds me, I need to add that to the shopping list lol. Yea you need to free up the mechanism all around so that it expands correctly. Otherwise the plastic tool pry's at location only. You'll ware it out lol.
I use a cheap oil line tool , it's narrow enough ~
You can also yank the filter from it's holder and turn to assist the penetrant (well, some you can). Then it's like others posted, towards the tool first / then back. What's a good rust inhibiter ? I can't think of the name dangit!! PB Blast ? Something like that, - I need coffee.
Old Nov 16, 2009 | 06:43 PM
f150fella08's Avatar
yep PB blaster "panda ****" its nasty yellow and reeks but it does the trick!
Old Nov 16, 2009 | 06:59 PM
ScrewedUPF150's Avatar
Just changed my fuel filter this past weekend and had to retry with the tool several times before the line released. Might have to give it 4 or 5 attempts before it comes off.
Old Nov 18, 2009 | 04:06 PM
wayne r's Avatar
Well I tried again this time with penetrating fluid and the set of plastic tools, and It finally it released, I got the new filter on and so far the truck has been running good, Hope fully this solves my problem, just wanna say thanks to everyone for your help wayne-r
Old Nov 18, 2009 | 07:23 PM
jbrew's Avatar
I would say your all high, they come off pretty easy. BUT, same thing happened to me trying to remove a FRAM replacement. It was a PITA. The bad about that, - it wasn't even my vehicle and I was doing this simple task as a favor. I should have went T&M on that job for sure lol.
Well, the connector wouldn't release and I lost control, turned a goofy shade of RED and found my SawZall..Yea, no damn fuel filter is going to kick my ***
Anyway, don't let this happen to you, use a OEM Motorcraft replacement fuel filter, - always! Those filters do an exceptional job, but need to be changed more often then recommended IMO. I change mine every 9000 miles (or 3rd oil change) and can't believe how nasty the fuel looks draining out of that thing. Never had a problem servicing with a Motorcraft element. Changing frequently enhances pump longevity. I have 170,000 miles on my second pump, - it works!
Thanks for posting, glad you got it, - they can be a mothuh.
BTW - If you purchase the Blue tool above, - get a couple of them. Their cheap in price, but the spring mechanism gives way after awhile. It's probably not the best tool for the job, but it's the one that has worked for me, time and time again.
Old Nov 18, 2009 | 07:27 PM
lmao! i remember that picture
yea i change mine at about 10-15k and its pretty nasty. but i drive around on a farm and live up a 1/4 mile dirt road
Old Nov 18, 2009 | 07:38 PM
jbrew's Avatar
Yea, that stuff! You can actually hear it battling that rust. You can also hear when it gives up lol. - Time for another application (or shot ).
Man! This site is dropping connection left and right , and half my post is missing
Well, a Ford Tech gave me half a can of some killer stuff that works better than anything else I tried. lol - he gave it to me after I told their service rep to get back to his post, you have custumers.. - Well he was trying to shu me out of the shop, -man some of those guys bother me. But I guess it was worth it, - I ended up with some good stuff
Problem, I can't remember what it was called.. Oh well, the can was Black and Blue lol
Old Nov 18, 2009 | 08:55 PM
jbrew's Avatar
Well, I wasn't going to post that pic. It's been posted so many times lol. Since YOU brought it up and since this obviously gives you pleasure -
_________________________
The Farm, this reminds me of a guy driving around with the parts I needed to fix the Oliver broke down in the field. It was early in the morning, - poor guy was a parts runner from John Deere and it was foggy as hell. I had him on the 2 way and he was lost. I asked for his location/cross roads and his reply was , - "I don't know! All I see is Corn, every where I look, there's just corn!!!" We finally met up about noon, after the fog burnt off..
Old Nov 18, 2009 | 09:02 PM
mustangraven's Avatar
fuel filter replacement is one of those jobs that seems so easy yet it can become frustrating when it does not go as planned. well luckily some people get alot of practicing changing theres ever 30k they wont have to worry about the clips seizing at least.
Old Nov 18, 2009 | 10:00 PM
yes brew it brings me pleasure
********** filter thats what it gets for bein a fram!!!!!!!!!!!\
btw howd you fix that line? put a new one on there since you obviously destroyed that one
EDIT* seriously it *'d that out??? sheesh
