Need a little help
Old Nov 3, 2009 | 08:29 AM
d_dyer's Avatar
Need a little help
Hey guys, I pulled the codes on my 88 f250 5.8L and found the following.
67: Neutral safety circuit failure. (I knew about this one, No money to get the part)
29: Insufficient input from vehicle speed sensor.
33: EGR valve opening not detected. (The Canister isn't hooked up, Will be soon though)
41:HEGO sensor circuit indicates system lean.
On 41 is where my question is. What is could be causing my lean problem?
Thanks!
Old Nov 3, 2009 | 08:42 AM
06 So Comfort's Avatar
That acronym looks like it probably stands for Heated Oxygen (O2) Sensor - The O2 sensor has an electric pre-heater in it to get it up to operating temperature faster. Either you have something that is forcing the engine to run constantly lean, or you have a bad sensor.
Old Nov 3, 2009 | 09:06 AM
d_dyer's Avatar
Probably the sensor, But the wires coming from the current one looks new. I guess it could always be a defected unit. Could it be a dirty fuel filter?
Thanks!
Old Nov 3, 2009 | 10:41 AM
Check for vacuum leaks.
