loud screeching!!
Old Oct 25, 2009 | 01:40 PM
Jr_WaxDr's Avatar
loud screeching!!
yesterday i just did regular maintenance on my truck 97 4.6L. I gave it an oil change, cleaned the air filter, changed out the rear diff fluid, and cleaned her up too. well when i cleaned it. i took it to the quarter car wash and sprayed down the motor to get some of the grease and stuff off. well that was last night and now this morning i start it up and i hear a loud screeching coming from under the hood. well i am wondering if the engine cleaning has anything to do with this noise. Last month i replaced the alternator w/ pulley, and the idler pulley. it almost sounds like its the water pump but i am not sure. Any help or guidance would be greatly appreciated. Thank you.
Old Oct 25, 2009 | 02:04 PM
jethat's Avatar
sounds like you got soap on the belt. If you didnt replace the belt maybe you should. if you did get some belt cleaner.
Old Oct 25, 2009 | 03:07 PM
Jr_WaxDr's Avatar
now the noise only starts at around 2500 rpm. anything below that it is gone. Soap can really cause this? ill try some cleaner.
Old Oct 25, 2009 | 03:50 PM
Camarothatcould's Avatar
soaks into the belt... I would take the belt off and scrub it with a mild wire brush... maybe a brass brush
