what piston should i use?? 5.4
i just put my truck in the ditch in some water and hydrolocked my number one piston and bent the rod and damaged the piston. so, i figure, nows a good time to upgrade. im just curious on what everyone is using for pistons and connecting rods.
what is stock type for our trucks? dish, flat top?? cuz if i put in a flat top by the sounds of it, it will have 10.8 compression ratio. so i have to assume that its a dish. but what brand is everyone using and where to get them
also, i was looking on modmax site. is that stuff mostly for the mustangs, or is the bottom ends the same as long as its a 5.4 2v? cuz i found some parts on there i want to use, but dont know if its the same or not.
thank you for your info in advance
