Getting frustrated Very Quickly
Old Oct 5, 2009 | 08:46 AM
ciocca1's Avatar
Morning! When driving up an off ramp or crossing the delaware river on the Betsy Ross, around 1500 rpm and roughly 40-45 mph, the motor stumbles for a quick second or two. Just changed the fuel filter and cleaned the K-N. Plugs were done at 85,000 and there is 103,000 on it now. Any help is appreciated. Thanx
Old Oct 5, 2009 | 11:11 AM
AZTriton's Avatar
If you just cleaned the K&N filter, starty by cleaning the MAF (mass air flow sensor). the oil from the K&N can get on the MAF and cause it to malfunction. Need to use electronic cleaner or CRC makes a cleaner for the MAF. I'm assuming the CEL (check engine light) is not lit; if so you need to get the code(s).
Old Oct 5, 2009 | 11:27 AM
Yes, clean the MAF and how long since the fuel filter was changed?
Opps, reread and see it was 18,000 miles. It should be ok, but I change mine every 15,000. If you got some fuel with water in it, could be the filter.
Old Oct 5, 2009 | 11:53 AM
ciocca1's Avatar
Thanx for the help. Going outside right now. I'll be back for more advice. Thank You guys both!!
Old Oct 5, 2009 | 12:47 PM
It could be a low grade misfire due to one or more weak coils - or use of non-Motorcraft plugs - or failure to use dielectric grease.
