Starter Won't Work
Old Sep 27, 2009 | 07:46 PM
Matts ford's Avatar
jump the firewall relay and see if it cranks.
Old Sep 27, 2009 | 08:11 PM
fritz4077's Avatar
100% sure its grounded to the bolt that goes in the tranny connected the starter to the tranny
Old Sep 27, 2009 | 08:12 PM
f150fella08's Avatar
like matt said, grab some pliers and jump the relay, key in the on position
Old Sep 27, 2009 | 09:02 PM
fritz4077's Avatar
can the relays go bad after awhile
Old Sep 27, 2009 | 09:08 PM
jbrew's Avatar
The firewall relay solenoid, - yes, but when they do, they usually click IMO. - They don't have to tho. Best way to check is to do as the guys have said, jump it, - but! do you know how?
Here's the lay out -
BTW - This is one layout, yours may and probably does differ, - this is just to give you an idea.
EDIT - This is indeed a 97-98 layout. Yours is different, infact , I may look yours up here in a minute, if you need it. ?
Old Sep 27, 2009 | 09:13 PM
fritz4077's Avatar
how would you go about jumping the relay
Old Sep 27, 2009 | 09:16 PM
jbrew's Avatar
Simple answer = YES lol. One way to tell is when their hot to the touch.
fritz4077's Avatar
yes i would need it i have a 01
Old Sep 27, 2009 | 09:19 PM
fritz4077's Avatar
i already typed it before you sent the last threat haha sorry
jbrew's Avatar
See were it says starter interupt relay on the diagram ? With no click, this could be the problem as well. There's qiute a few areas to check.
Old Sep 27, 2009 | 09:24 PM
jbrew's Avatar
An 01? I thought you had an 04 ? I had an 01, yea their different. You might have a PATS problem as well. SEEE , could be this , could be that lol.
Your theft light would be blinking KOEO. Do your gauges sweep at KO ?
Old Sep 27, 2009 | 09:28 PM
fritz4077's Avatar
you here a click to the relay when u turn the key for just the power on...thats in the fuse box the starter interupt relay correct
Old Sep 27, 2009 | 09:29 PM
fritz4077's Avatar
no they dont i took the pats off....i got a custom tune from my tuner
Old Sep 27, 2009 | 09:34 PM
jbrew's Avatar
Well make up your mind
Here's the Relay or Solenoid to jump on the firewall -
ok dude to jump the relay, take some pliers and touch them on the 2 copper looking (i think they are copper or brass looking) bolts and it will spark and (hopefully) try to start if not start
