fan clutch is probably bad... need help
Old Sep 11, 2009 | 06:55 PM
speepdaedeesi's Avatar
03 screw 4.6l
the fan sounds like an airplane taking off... spinning at full speed with a cold engine.
im guessing i have a bad fan clutch.
anyone have some quick tips on getting it out and replacing?
thanks
Old Sep 12, 2009 | 02:20 PM
anyone?????
so i took it to the carwash and pressure washed the motor, paying special attention to the fan clutch...
i am able to turn it by hand, with slight resistance as it should be, so i dont think its locked up.
coolant level is fine, or at least theres the correct amount in the overflow. i cannot check the radiator without taking the fan shroud off... if i need to let me know.
i think it might be some sort of sensor keeping it on?
anyone?
Old Sep 12, 2009 | 04:27 PM
jbrew's Avatar
Yea they get noisy sometimes, but very rarely wear out. Pretty reliable systems, - Power robbers= They steal about 15 RWHP. If by chance it is bad, you'll see oil stains from leakage on the housing.
I replaced mine at about a quarter million miles, - still sounds sort of like you describe , - not all the time.
