How to remove crank pully
Old Aug 28, 2009 | 08:24 PM
fritz4077's Avatar
Exclamation How to remove crank pully
how do u remove a crank pully on a ford lightning...i rented a pully puller that looks like a claw and started cranking on it but it was just messing up the pully by pulling the sides out..is there another way to get it or just keep going with it
Old Aug 28, 2009 | 10:50 PM
Tumba's Avatar
I've enver worked on an L. But this is the tool to pull the harmonic balancer.
Old Aug 29, 2009 | 09:40 AM
jaymz's Avatar
Jeez man, do a little research before just cranking away; there is info all over the 'net on this procedure, especially on Lightning/SVT-specific sites like NLOC, etc.
The supercharger pulley screws off, and it's a reverse thread (clockwise to loosen). You will need a 1/2" breaker bar (at minimum) and the appropriate allen wrench (14mm?) in the hub of the pulley. Remove the cage from around the pulley first.
You will also need to lock the transmission to prevent the crank from rotating while removing the pulley. You remove the dust shield on the flywheel case and fab a metal tab from flywheel to dust cover bolt hole.
Then, if you're incredibly lucky, the pulley will break loose. They can also be incredibly impossible to remove. If it doesn't come loose easily, you'll need to put a floor jack under the breaker bar (plus cheater bar) and slowly raise the jack until the pulley breaks free.
Many pulley kits include the allen wrench and tranny lock tab.
Also do a search for more info.
Old Aug 30, 2009 | 04:09 PM
Veteran: Army
I hope you weren't cranking on an aftermarket supercharger drive pulley, they have 3 bolts inside the hub
we need some pics so we can see what you are doing wrong
Old Aug 31, 2009 | 10:24 PM
Steve83's Avatar
What year? What engine?
Old Aug 31, 2009 | 10:32 PM
Matts ford's Avatar
he's got a 5.4 lightning engine.
