1997 5.4l runs rough
Old Aug 27, 2009 | 10:27 PM
NathanY's Avatar
Unhappy 1997 5.4l runs rough
Hi all, I'm new to the forum and I need some help with my 1997 Ford F150 4X4 with 5.4L engine. It idles good, and runs down the highway good. But when you are cruising down a road say at 35mph where the rpm's are around 1000-1400 it runs rough and the rpms jump, kinda like chugging. I was getting a EGR Flow Excessive, so I replaced the EGR controller and the EGR valve, no change, except is idles good now. When the truck is in park, I can bring it up to a high idle, around 1200 and make it chug. It only does this between 1100 and 1500 rpms, in both drive and park.
Old Aug 27, 2009 | 10:37 PM
torkum's Avatar
Sounds like a low grade misfire, when is the last time you changed the cops?
Old Aug 27, 2009 | 10:47 PM
NathanY's Avatar
What are cops? If they are the thing that goes between the coil pack and the spark plug, mine has the one piece coil pack/plug tube. As far as I know, the spring and tube, aren't replaceable without replacing the whole coil pack. Last time I had a misfire, I got a code, and replace the coil pack and plug, and the code went away. #7 & 8 have both been replaced. May have a plug breaking down. That is the next step in my maintenance schedule. Truck has been a good one, 235,000 and only new A/C compressor, 2 Coil packs, and rear diff reseal.
Old Aug 27, 2009 | 11:12 PM
NathanY's Avatar
Okay so the CoP's are actually the coil pack that goes on the the plug, the whole unit. Number 7 & 8 have been replaced. They both gave me fault codes when they started going, and were replaced along with the plugs. Is there a way to test these coil packs to see which one is going out when you dont have a fault code? at 45-50 dollars a piece, I cant just go changing out parts.
Old Sep 30, 2013 | 11:55 AM
Crandrews15's Avatar
Hey did you ever get this one figured out? I've kinda got the same problem going on with my truck. thanks!
