Code P0054
Old Aug 25, 2009 | 07:47 PM
The Punisher's Avatar
Code P0054
My CEL turned on today and I pulled the codes... Code P0054 came up...Im assuming the rear driver side 02 is bad correct?
Old Aug 25, 2009 | 09:32 PM
Matts ford's Avatar
P0054 HO2S Heater Resistance (Bank 1, Sensor 2)
check and see how many volts are going to the sensor through the heater circuit, i mean check the harness side not the sensor side.
Old Aug 25, 2009 | 09:35 PM
torkum's Avatar
I think you mean P0154 (if you got a 96 up) and check the wiring going to the sensor before replacing it. That code indicates no activity like it is unplugged.
Old Aug 25, 2009 | 11:52 PM
P0054 is what came up, not P0154. And thanks.
Old Aug 26, 2009 | 08:35 PM
projectSHO89's Avatar
How about properly identifying your vehicle so we can know which reference to consult?
Old Aug 26, 2009 | 09:04 PM
Haus05's Avatar
Profile says 04' F150 SuperCrew(New body style)
Old Aug 30, 2009 | 11:29 AM
Whoa sorry guys! I thought I had my vehicle on my signature sorry!!! Thanks Haus05
Old Aug 30, 2009 | 11:34 AM
It is on my signature when I go on UserCp. Weird...
Anyhow code P2270 came up also! Stuck lean...Now if both those are for the rear o2s im just gonna tune them out. my friend whos a pretty good tuner will charge 100 bucks to tune it for me and tune them out as I will just delete my cats.
What the hell I have a signature now!!!
Old Aug 30, 2009 | 12:34 PM
LincolnMarkLT20's Avatar
I had my o2 deleted, when I installed cats 94106. Good thing I have SCT X3.
Old Aug 30, 2009 | 12:42 PM
Matts ford's Avatar
both codes are for the same sensor. it wouldnt be smart to turn the sensors off when they are showing codes. you need to find the problem, then when its fixed you can turn them off. if not, then like the code says its stuck lean which is very bad for an engine-parts will fail internally depending on how lean its running. is there any exhaust leaks? check your intake manifold seals make sure there arent any vacuum leaks. how olds the fuel filter? make sure the injectors are all working properly. maf ever been cleaned?
Old Aug 30, 2009 | 01:44 PM
I assumed that those codes were for the rear o2. I always thought that sensor was just to tell the computer if the cats were bad. Cuz if they were that important, turning them of would be a bad idea no matter if the light was off. Because you would never know if that could come back again and then bite you in the *** lol .
Old Aug 30, 2009 | 01:45 PM
double post
Old Aug 30, 2009 | 02:07 PM
Matts ford's Avatar
the rear sensors monitor the emmisions. the front sensors mess with the a/f ratio. the main reason for turning the rear sensors off is for taking off cats without throwing a cel. but if there is a problem then turning the sensor off is just hiding it. if there is in fact a problem then it will still exist and you wont know it, which is why i said you need to make sure the problem is fixed. if it is just the sensor then you can go ahead and turn them off but i was just saying to fix the problem first if there is one.
Old Aug 30, 2009 | 07:15 PM
I totally understand about fixing the problem first which i am as soon as its not 120* outside lol.. But if in fact they are important how would I know if it came up again if they are of? I mean i would never know... I just want this truck to last me like forever so I can save up for other things. But i would rather disable those codes if they are kinda worthless and just gonna cause me to spend money on it. Get my point?
