Engine running rough
Old Aug 19, 2009 | 01:49 PM
TerryTee's Avatar
We have a 2003 F150 V-8 with 63,000 miles. We got some bad gas a couple weeks ago and it ran awful. We used a fuel addittive to dry the water and then used a couple containers of the Lucas fuel additive. We had the system checked (for the service engine soon light) and was told it was a mis-fire on # 4 & 5, so the plugs were replaced and so was the fuel filter.
The engine still has a miss after first cranking, at idle and usually at slow speeds. We do not have the $$ to take it to the dealer and have them start throwing parts on it.
What can we do/check on our own to get it running right? Someone told me the coil packs may be bad and it was a "known" issue with the F150, but considering he thought the truck was a 1998 and that bad gas really did not hurt the engine or cause problems, I am not too sure he knew what he was talking about.
Thanks for any suggestions/info.
Old Aug 19, 2009 | 02:04 PM
Tumba's Avatar
The best thing to do, would be to go to Autozone, or Orielly's or similar place and get the OBDII codes checked. Depending on where you are , in most states they will do it for free. But before you buy parts, post the exact code numbers here for advice.
Welcome
Old Aug 19, 2009 | 02:32 PM
TerryTee's Avatar
Thanks Tumba. We did go to Advanced Auto and they just said mis-fire on # 4 & 5 but I will go back and get the exact codes.
Thanks!
Old Aug 21, 2009 | 01:15 PM
TerryTee's Avatar
Ok we have the codes - P034 #4 cylinder misfire & P035 #5 cylinder misfire. The plugs still looked good but we changed them anyway and we changed the fuel filter.
Any suggestions? Thanks.
Old Aug 21, 2009 | 02:07 PM
Tumba's Avatar
Did you try trading the cops with different cylinders?
Was there any water or rusty looking deposits in the cop boots?
But I would try changing the cops with two other cylinders that are easy to get to, and see if the miss follows.
Old Aug 21, 2009 | 02:11 PM
Tumba's Avatar
Did you replace the plugs with OEM Motor Craft?
Old Aug 21, 2009 | 02:36 PM
TerryTee's Avatar
We used Motorcraft plugs. We will try to swap and see what happens. Thanks.
Old Aug 21, 2009 | 02:50 PM
TerryTee's Avatar
Correction, the DTC codes are P0304 and P0305, sorry.
