2001 hesitates and throws mass air sensor code
I have an 01 with a 5.4 and airaid intake. the service engine light comes on and says the MAF is not getting enough power. When you put it in gear and push on the gas it hesitates for about a second and then takes off.... ??? I have cheked all the wiring and fuses and everything looks fine...
A P0102 cannot be caused by a contaminated MAF sensor.
Either the sensor is bad, the PCM is bad, or there is a wiring fault in the MAF circuit.
See the PCED for the diagnostic procedure.
Ok so today i installed new MAF meter and guess what.. No difference.. So how do i check for a bad PCM? My truck has a custom tune could it just need reflashed and reprogrammed??
