Fuel Injector Help Please
Old Aug 10, 2009 | 03:08 PM
medic299's Avatar
some of you may have been following my woes on another thread and realize i am replacing a 4.6l W 2003 with salvage 2006 4.6l W....i am replacing the intake to use mine as a suggestion here. Can i use the rail and injectors from the 06 instead the 03's? If i do can i still use my COP's? any help is greatly appreciated. Darrell
Old Aug 11, 2009 | 07:51 AM
Veteran: Army
is the '06 a return or a returnless fuel system????
I don't see why you can't just use your old fuel rails and the new harness
Old Aug 11, 2009 | 09:27 AM
medic299's Avatar
not sure whatcha mean about returnless, looks same as mine except injectors appear shorter
Old Aug 11, 2009 | 09:47 AM
jbrew's Avatar
I didn't think it could be done that easy. Regardless, it's got to be a PITA with the different computers and Drive by wire system. I haven't heard of anyone doing this, hope it works out. Curious to see if it does.
Old Aug 11, 2009 | 09:56 AM
Veteran: Army
look where the fuel lines comes in, on your truck should have a large line coming in and a small line going back to the tank
hopefully you will run your trucks factory fuel rails and intake manifold to make your swap easier,
Old Aug 11, 2009 | 10:08 AM
jbrew's Avatar
It got quiet lol. Yea, he would have to use EVERYTHING from the injectors up off the old engine.
Hey Jer , is it just me or is this site hanging a little?
Old Aug 11, 2009 | 10:18 AM
medic299's Avatar
i am using old intake, there fore i should just stay with same injectors and fuel rail. Good deal thought maybe since the 06's only had 38k i would use them vs the 115k on mine....thanks for your help again jbrew....i will be posting soome pictures in near future...when i went to change oil pans found several large pieces of white plastic and oodles of metal filings as well as near clogged pick up tube
