my new 351 Windsor
sweet. is it still 351 ci? or is it stroked and bored? how much power is it rated to put out? looks good
edit: saw pics of the truck in your album and its pretty sweet too.
it is bored 40 over. the guy who built it for me has not told me what he thinks the power is plus it has racing pistons and a bunch of other modifications which he has told me but i couldn't remember them. He told me if has a 3/4 cam in it. It has aluminum trick flow heads. The guy currently restoring the truck has the motor and all of the other components like the carb and i know its a Holley but im not sure what size it is
That looks like a Cleveland. The Windsor had straight spark plug holes, and the Cleveland had the angled ones. Maybe my memory isn't so good.
Sweet engine, which ever one it is
I had a 72 4wd with a Cleveland and 4 in the floor. Would pull anything you could hook to it stock
We also used it in the hay field, and could put it in granny gear, it would idle and drive between the rows of hay. We could put 70 bails at a time on it, and never touch the throttle, it would just idle along.
With a goose neck easily pulled Jd2020 crawler, tractor or ford 2000.
I still miss that truck.
We also used it in the hay field, and could put it in granny gear, it would idle and drive between the rows of hay. We could put 70 bails at a time on it, and never touch the throttle, it would just idle along.With a goose neck easily pulled Jd2020 crawler, tractor or ford 2000.
