throtle position sensor problem
Have any of you heard of 3v 5.4l having tps sensor issues . I'm finding this is very common . I thought it was a coil but it turned out it was the tps
Mine showed the code after I installed a new battery I then unhooked the neg battery cable to reset the computer and now no code ... It has also pulled a knock sensor code before and the same remedy fixed it.. the truck is running fine..
what exactly is it doing? what year? what are the codes?
